RDMueller's avatar
RDMueller
Pay at the pump at truck stops
Although I technically can get into some gas stations when towing, I personally prefer using truck stops since it's just easier, plus you don't have to deal with someone parking their mini van in front of the only diesel pump for 20 minutes while they are inside on a shopping spree.
My only complaint about the truck stops is that for some reason most of the ones I've been to don't take personal credit cards at the pump. So I'm stuck going in, waiting in line to hand them my card, go out to pump the fuel, and finally go back in to pay, all the while holding up the truckers who I'm sure are eager to be on their way.
Any solutions that you know of? Are Pilot/FlyingJ locations usually the same or is there an option for non commercial operators to get a card that does work at the pumps? Just curious what others do when stopping for fuel. As always, thanks for the advice!
  • the bear II wrote:
    Most of the time I fill up when I'm unhitched from my 5th wheel; fill up the day before we leave or right after we arrive. Most trips we take require less than one tank to get to our destination. So it's just easier to fill up once we unhitch.
    That's what I've usually been doing as well for most of our trips, but we are planning a long trip for spring break and will most likely need to stop for fuel while towing. Good to know that some truck stops have RV lanes. I'll have to look for those.
  • I use the Flying J card and pay at the pump. It is available to all. Savings at the pump also. If you half to go inside to use your credit card it is just part of the drill. Once full, just pull up so the next vehicle can get in as you settle up.
  • Some truck stops have RV lanes with credit card accepting pumps. Normally I fill up at the larger service stations you see along the highways and haven't run into having to wait for the mini-van shopper. I've only filled up at one truck stop using the trucker pumps, I was able to use my credit card at the pump.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
