BigSpenda864's avatar
BigSpenda864
Payload Capacity and Towing Questions
I Will start off by saying that I heavily researched the type of RV I wanted and was dead set on a bumper pull travel trailer over a fifth wheel. I wasn't ready to buy my RV yet but had to go ahead and purchase a new vehicle that would be my tow vehicle. I opted for a 2018 F250, Crew Cab, 4WD, Platinum, diesel. The truck will tow any travel trailer (or fifth wheel for that matter) that I am considering. The problem (of course) is payload capacity, something I knew nothing about at the time of my truck purchase two months ago. I was told at the Ford dealer, and every single RV dealer I visited (and I visited a lot of them), that the F250 I was going to buy could tow "everything on the lot except a few of the biggest fifth wheels." Due to all the options on my truck (which is very nice I must say), and the fact that it is a 3/4 ton, my payload capacity ain't great.
Now, I've started question whether I would prefer a fifth wheel. it would not exceed 35' in total length with advertised hitch weight ranging from 1600# to 2300# (I realize a loaded trailer may increase these numbers).
So here are the truck's numbers:
GVWR: 10,000
Front GAWR: 5200
Rear GAWR: 6340
Payload Capacity: 2145
So the questions are:
A fifth wheel with a hitch weight of 1600# will exceed my payload capacity once its and the truck is loaded with my family and junk.
1. It appears the negative effects of exceeding the payload capacity of the tow vehicle are: possible legalities, wear and tear, and safety. Any others?
2. What ways exist to counteract the negative effect of the wear and tear and safety? Air bags, more suspension, etc? I realize the trucks official payload cannot be increased but are there ways to safely handle the higher payload safely.
3. Do these solutions truly counteract the negatives of my payload limitations?
  • GWVR and Payload ratings (a byproduct of GVWR) are MFG warranty issues and Vehicle Registration issues...NOT 'criminal' issues
    Axle/Tire Load Ratings ARE DOT 'LEGAL' issues
    SO stay AT/Under the Axle/Tire Ratings
    2018 250/2500 can handle the WET pin weight of a 14K 5th wheel W/O going over the RAWR/Rear Tire Load Ratings.
  • I tow 200 lbs over my GVWR. 1100 lbs under the RAWR. 3200 lbs under tow rating and 2000 lb under my rear tires max load. My towing experience is about as good as it gets. Except for slower acceleration and longer stopping distances from pulling 9000 lbs I don't even feel the 5er behind me. As long as you're under the RAWR, tow rating and GCVWR you won't have any trouble. I'd have no problem adding another 500 lbs to my RAWR.
  • I tend to try to encourage people to be fairly true to ratings, but I wouldn't squawk at someone being 50-100 pounds over a 10k GVWR. That said, the number you are toying with are going to result in you being more like 500-1,000 pounds over! My short answer is no, I don't think there is a reasonable way to counteract that significant an overage.
    Go back to the TT idea - you can get plenty of trailer and stay well within your ratings. We have 2,100 pounds of payload and we tow a 35' trailer, a family of 5 and a 100 pound dog - all while staying well within our ratings!
    GVWR: 10,000
    Front GAWR: 5200
    Rear GAWR: 6340
    This is as it left the factory and unless you plan to tow as it without any additional loading..and you weigh 150lbs (that is the stand used for any person in the vehicle)...this capacity number will be wrong
    Best to load up as you would ready to go RV'ing and weigh it axle by axle.
    Then do the simple math to find out what is left on your GVWR and especially RGAWR
    Most of the stuff recommended/advised/etc will change the orientation (how it sits statically and dynamically, but the ratings will be the same...unless you pay a PE/ME to certify a new rating...but that would cost more than just going out and buy a higher class TV
    In my city...saw both the city PD and Highway Patrol making all vehicles stop on their portable scales. Didn't stop and turn around, as they might have made me enter that marked off lane
    Cousin used to be a Sargent in Calif Highway Patrol and used to stop any setup that 'looked' over, but he was made to stop doing that after too many letters to management. He confirmed with legal that he was within the law, but too much politics on that one...he finally quit after one of his officers got his knees taken out walking between cars after they hit each other...back then bumpers had shock absorbers that got stuck compressed and let go later and the dead infant he had to pull out from underneath the dash
    Saying non-commercial will/might soon have to toe the OEM/DOT/etc ratings...as eyeballed them weighing non-commercial in my city last month
    Of course safety...OEM components are designed to manhandle the setup during a Mr Murphy meeting...while at those OEM ratings limits. Going over will have the setup less able to manhandle that setup
    Get a bigger or next class TV. It will be able to manhandle more and better during that Mr Murphy meeting
    Sure in a way, but not the ratings. Take my vehicles. They all have highest performance braking components and my own special tune. My K3500 Suburban has out stopped a BMW 5 series where he bumped into my rear bumper. Didn't know he was 'trying' out drag me while out and about enjoying some new mods and retune of stuff. Running WOT from stop light to stop light...but my K3500 is still an 8,600 GVWR and 425 FGAWR and 6,000 RGAWR.
    Tongue'n cheek refer to my Sub as a K3500...knowing GM never offered one. Ordered the F60 option to get 1 ton front springs. AAM rates my axle at 10,000 GAWR, but GM installed brakes/springs/etc lists it at 6,000 GAWR.
    Note that there is only one person responsible for the setup and that is the driver. Even you chose all of the stuff, the driver is responsible...and...no one here on this freebie forum has any skin in that
    Laws of physics dictate all of that and another note...the TV is s whole system.
    Changing something (re-engineering) must take that whole system into account...where most only address a single to a few of the whole
    Finally...all things designed/engineered is for the specification that addresses the worst case (AKA meeting Mr Murphy). All of the OEMs CYA themselves via their specifications and fine print on all ratings. When you re-engineer anything...know that and make sure that your re-engineering is ABOVE their spec and note that you now own the liablity of it all
  • You can reduce squatting with air bags.
    I've seen 250s pulling things that dwarf them, but that doesn't make it safe. I guess it depends on how MUCH towing you're going to be doing. You can get away with overloading for a time.
  • You have your GVWR, now you need to know exactly how much you weigh loaded reafy to travel. Subtract one from the other. Thats your real world payload. Once you subtract 150 to 250 pounds for hitch you will be surprised how little you have left over for pin weight. Fifth wheel pin weigh%t will generally be about 20% of the fivers LOADED ready to travel weight.
    Once you know those numbers you can then safely make a good judgement decision. You will get lots of " no problem, tow a 40 foot fiver" comments soon. Im not going to tell you yea or nay. Do the math.
