MrWizard
Jun 07, 2016Moderator
Your power systems auto start monitor, is the special part
Any 50 amp RV transfer switch will work
Better.. Best ?
IMO yes.. There is one brand that has mechanical interlock between the two relays and coils used in a 50 amp switch
Quality 50 amps switch uses two separate relays one for shore one for generator
When one is on the other can Not be engaged
Even if you open it up and pushed it with a stick it could NOT engage
Almost Impossible to create an accidental short circuit between generator and shore power
If I can find it again I will post it
Better.. Best ?
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
