RiverRat78's avatar
RiverRat78
Planning Mountain Trip
I have a Toyota Tundra and a 2011 North Trail 28' 5600lbs dry weight and looking at pulling camper to the mountains next year. My truck pulls this camper like it isn't there and brakes on camper and truck with great. What are some things for a newbie pulling a camper into the mountains? I've pulled many TT campers and boats just not in any mountains. What would be any advice you'd offer to someone new to pulling in mountains? Thanks for any advice?
  • Use lower gears going up hill to keep the engine RPMs up. Better engine cooling.
    Manually shift to lower gears going down. Do Not ride the brakes. Let the engine do all the work.
    I drive the mountains all the time.
  • Typical advice is, whatever gear you use to climb the mountain, use the same gear to descend. So, if you're on your way up and your truck is "searching" for the best gear (shifting back and forth a lot), select the lower gear for it. Stay in that gear as long as you need to. As you near the top, you can put it back in its automatic mode. Then, on the way down, when you find yourself braking a lot, put it back in that lower gear and use the engine to brake. You don't want to ride your brakes all the way down, that's for sure. As you begin to reach the bottom, and engine-braking doesn't seem necessary, put it back in automatic.
    In my experience, the braking part is more important than the climbing part. My first time through the Rockies with a trailer I pretty much burned up a set of brakes because I didn't know about this rule of thumb.
    Good travels!
    -Speak
Looking for advice before your next adventure? Look no further.25,157 PostsLatest Activity: Aug 19, 2025
