jerem0621's avatar
jerem0621
Explorer II
Apr 11, 2015
Please check some measurements.
Hey guys, need an opinion here on if I should buy a WD hitch for our awesome POP up and Minivan combo, leave as is, or just go with some Timbren's/Airlift Airbags to level it out in the rear.
The Trailer is 2900 ish lbs GVWR and we towed the rig home with nothing but the ball and a sway bar. Towed great! No control or handling issues at all. I took some initial measurements with the rig moderately loaded.
Like I said the rig rides great, but here are some pics.
Unloaded measurements
Unloaded Rear wheel well
Unloaded Front wheel well
Loaded Measurements
Loaded Rear Wheel Well
Loaded front Wheel Well
Looks to me like my front end measurement is 31 1/16th and my unloaded measurement is 30 3/4 giving me way under .5 inch rise in the front wheel wells loaded up. Not too bad!
The rear end does squat of abut 1 1/4 inches... but like I said, the handling is still very good. Once the family is all loaded up in the van the rear end squat is about 1.5 inches and the front has negligible rise.
I must say that hitching up by just dropping the coupler on the ball does appeal to me, its a few less steps and less weight than a WD hitch and my handling seems great as is.
I would like to do something about the rear end, Timbrens appeal to me most because they are an install and forget. I am not worried about the squat as much as I am the rear end handling once we are fully loaded up. A WD hitch will take car of it too, but there are WELDED ON obstructions on the Trailer A-frame in the way. AirLift airbags will level out the rear back to stock so that may be the way to go.
Thanks for taking a peek at my post.
Thanks!
Jeremiah
  • Looks good the way it is. No need for a WD hitch unless the receiver rating calls for one. You're always going to get some suspension drop with weight added. 1.5" is not excessive.
  • That all looks pretty good to me the way it is.
    However, I would check what the vans manufacturer says about tongue weight where a WDH is required. If you are below that number then your good to go as-is.
