donn0128
Nov 19, 2015Explorer II
Truck GVWR minus scaled loaded ready to travel weight equals cargo carrying capacity. In the real world that means your truck, full of fuel, passangers and all the gear you would normally be traveling with. Add 250 pounds for a hitch. As for your fiver, easiest to assume your trailers GVWR, 20% of which is pin weight.
Soooo, if your truck scaled at 8,000 pounds and has a 10,000 GVWR means you have 2,000 cargo carrying capacity.
Fiver GVWR 17,000 pounds, means you will have 3,400 pounds of pin weight. Based on my example your truck will be 1,400 pounds over its GVWR.
Is that simple enough?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
