transamz9
Nov 21, 2015Explorer
mkirsch wrote:
Trying to keep this as simple as possible:
As a rule of thumb, the fifth wheel capacity of a pickup truck is roughly 5 times its payload capacity, after you've loaded yourself, your family, and anything else in the truck.
You will *NEVER* be able to tow the maximum amount stated in the towing guide. It is a theoretical maximum based on ideal conditions. The truck has to be empty except maybe one passenger. The trailer has to be balanced perfectly with just the right amount of pin weight. That *NEVER* happens in the real world.
Quick Example: The F-250 you were originally looking at typically has a payload capacity of around 2300lbs. A 5th wheel hitch weighs about 250lbs. So you'd have about 2000lbs of payload to work with. 5 times 2000 is 10,000lbs. That's roughly the heaviest trailer you can tow with that F250.
Never? I'm towing 20,000 with a SRW 3500 and with-in payload capacity.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
