westend
Dec 08, 2016Explorer
wanderingbob wrote:320W mono kit from Solar Blvd: 320W w/free shipping $369
Amazon has a Renology 400 watt kit for $626 . What do you guys think of it ? I have measured the roof on my Work and Play and it will fit up front close to my four six volts . Wires will run behind the air foil on front to batts on " A" frame .
I'm having good luck with a 235W 24V panel and a morningstar MPPT controller. The larger panels and a better controller may be something you should consider if your roof will fit them.
Sun Electric has a warehouse in Miami Gardens, FL. Solar Blvd is supposed to be shipping from TN. Shipping is a killer with solar panels since they are considered "oversized".
BTW, there are only a couple of solar charge controllers that can be used exposed to weather. When you explained your routing, there wasn't mention of the charge controller. You want that as close to the batteries as possible.
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
