wildtoad
Mar 18, 2014Explorer II
I have not done intense testing but I suspect the flow problem is as Bud mentioned the regulator not the filter. I'm OK with the reduced flow when using my holding tanks as it help to prolong the time between dumps. If I just use the blue filter, flow is great. Add the brass regulator and it makes a big difference.
Have you tried a different filter in the canister as if like the one I had at my last house they had several options in regards to particle size captured.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 25, 2026
