wa8yxm
Sep 17, 2018Explorer III
You are close
50 amp service (Many threads here show how the outlets are wired) 4 wires. L-1 (hot) L-2 (hot) neutral and safety ground 240 volts divided into two 120 volt legs. double ganged breaker
30 amps.. one hot, neutral and safety ground (3 wires) SINGLE 30 amp breaker.
IF you have 30 installed Make sure it is a single breaker and mEASURE teh voltage BEFORE you plug in.
50 amp optional. Wire as you would 50 amp regular but use 30 amp breakers.. Most 50 Amp RV's will work fine this way.
Now. plugging a 50 amp rig into 30 amps. Use a proper adapter and it will feed BOTH legs on the RV. but you can not use everythign at one time..
If you remember the old Green Acers TV show where Oliver had put numbers on all the appliances and you could not plug in more than I think it was 10.. Well numbers and you can not plug in more than 30
Fridge is a 4.. Coffee pot a 7 (most electric kitchen stuff is 7-10) MIcrowave 11 A/C's 14 water heater 12 that kind of thing. if the total is over 30 CLICK and darkness.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 17, 2026
