SDcampowneroperator wrote:
short term visitor campground power pedestals undergo extreme plug in/ disconnect cycles. That wear and usage does warrant visual inspection and suspect breaker function. The camp needs you to report what you see.
Alert the camp mgmt right away if you suspect worn,or weak electrical equipment.
I tried letting a CG mgmt know when my trusty voltmeter showed just 103 volts.The reaction? "Duhh,I'll tell the owner when I see him"I made an attempt to explain why it was important...more "duhhh."She did assign me to a different site that had full power.
