Smokey_Lew's avatar
Smokey_Lew
Pondering between Ram 2500 or 3500
Hi guys and gals,
I've finally decided to trade in my 2011 Ram 1500 for either a 2500 or 3500. I have an older heavy TT that has a tongue weight of 1,050 lbs. When loaded, we have about 7,500 to 8,000 lbs. The TT has a GVWR of 10,000 and its UVW is 6,600.
We really like the TT but it's been a white knuckle ride pulling it with the 1/2 ton truck. The trucks payload is only 1354 and I'm afraid of breaking something on the truck if I continue pulling this load. With my wife, myself, two dogs, and all my junk in the back, I'v already gobbled up 800 lbs. of the payload before dropping the trailer on the hitch
Anyway, The 2500 has the same type of coil spring rear suspension as my current truck and I'm nervous about dropping 1,000 lbs on the back. The 3500 has leaf springs on the rear and it's much stiffer. The thing is with both trucks set up the same, the cost difference is only 300 bucks. Logic tells me to go with the 3500 but I'm wondering if I'm overlooking something about the two trucks that I should know before placing an order.
I'm going with the 6.4 HEMI and 4.10 axel ratio regardless of the truck I decide to go with. Can't afford the added cost of a diesel or the maintenance costs. Had no problem with power using the 5.7 HEMI in my 1500.
Any thoughts on this would be helpful. I'd like to place an order for my new truck in the next couple of days.
Thanks,
Smokeylew
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
