Karfae69's avatar
Karfae69
Portable Generator Security
We are getting a pair of the Yamaha EF2000is to run our RV when we dry camp at various race events or elsewhere tired of our noisy onboard. Will run while we are gone during the day and at evenings close I can always bring inside. Other than a high quality cable and lock system do I need to go beyond this? I suppose I could hire private security or put my lazy dog next to it. Is theft a real concern that I need to go over the top?
  • People ask about securing gennys regularly. With that said, how many have actually had a problem with someone taking their generator? I'm curious to see real numbers of those that have had a generator stolen, and how it was secured at the time. Don't include "I heard of" or know someone, only direct experience. Is this a really big problem, or just a really big anxiety?
  • I have a small motion-sensor alarm. I have this model;
    http://www.gofastandlight.com/Portable-Motion-Sensing-Perimeter-Alarm-for-Camp-and-Tent/productinfo/E-DBL-MOTION/
    Portable Motion Sensing Perimeter Alarm for Camp and Tent
    It has about a 60 degree wedge shaped area of detection about 30' out. Anything moves within there it makes a very load noise. It uses a 9 volt battery. It's also really cheap.
    It will not trip for leaves, very small animals, etc, but a cat-size critter might. You also have to watch out for wind, if you just sit it on the ground, or on something else without it being held securely. I just put a rock or something leaning on it to hold it steady.
    In on of the first campground I stayed at, a National Forest campground, someone came by in the middle of the night and used bolt cutters to steal about a dozen generators while their owners were sleeping inside their rigs. Chains won't stop some thieves.
    If you are leaving your campsite, either put then in your rig, or take them with you, as I do. I have two plastic boxes with lids that I keep my two Yamahas in.
    I won't stop someone who breaks into your rig, but they would have to try it in broad daylight in my case.
  • If someone wants it bad enough, they will take it. Since you have an onboard, I would suggest running the onboard while you are away and use the Hondas while you are at the RV. Put the Hondas out of sight while you aren't on site. Otherwise, a really heavy chain or cable.
    -Michael
  • I place mine out of sight. Usually chain it to a tree at the back of the TT where it can't be seen from passers-by. It's so quiet, you don't even know it's there.
    Otherwise, I put it in my van when I don't use it.
  • I use a U type bicycle lock through the handle & my bumper to secure my Honda Eu. Previous poster is correct . Really nothing will prevent theft. Make it hard. I like the armed security guard idea.
  • NOTHING will prevent theft.
    Just make it look difficult, so the robbers will move on.
