bshpilot
Sep 04, 2014Explorer
Jim-Linda wrote:
A number of errors in this statement.. There is NO fuse under the black cover, there are however, a 120vac t/stat on the left side and a 12vdc t/stat on the right side. Both have a resettable "button" on the top stat. There is nothing to visually check, except maybe a burnt wire. Next, the element will open up almost instantly if no water is in the tank.
on a SUBURBAN water heater....
the high limit "wire" WILL melt (like a fuse) BY DESIGN - to interrupt power to the heating element, its there for the very purpose of preventing damage to the electric element.
you can VISUALLY see the wire/fuse when you remove the black cover which has the reset switches on it.
IF the high limit melts the fuse/wire, you can NOT heat water (via the 120vac element).
I know, because this has happened to me, if the fuse/wire is "OPEN" simply replace it (and you should be heating water via the electric element).
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 18, 2026
