Jim-Linda
Sep 04, 2014Explorer II
bshpilot wrote:Jim-Linda wrote:
A number of errors in this statement.. There is NO fuse under the black cover, there are however, a 120vac t/stat on the left side and a 12vdc t/stat on the right side. Both have a resettable "button" on the top stat. There is nothing to visually check, except maybe a burnt wire. Next, the element will open up almost instantly if no water is in the tank.
on a SUBURBAN water heater....
the high limit "wire" WILL melt (like a fuse) BY DESIGN - to interrupt power to the heating element, its there for the very purpose of preventing damage to the electric element.
you can VISUALLY see the wire/fuse when you remove the black cover which has the reset switches on it.
IF the high limit melts the fuse/wire, you can NOT heat water (via the 120vac element).
I know, because this has happened to me, if the fuse/wire is "OPEN" simply replace it (and you should be heating water via the electric element).
I have replaced 4-5 t/stats over the years on SUBURBAN HEATERS and have yet to see a fuse/fusible link or other device as you claim. May be getting blind, but after replacing the stat, the element came back to life.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 18, 2026
