buta4's avatar
buta4
Potti Odors
Greetings,
For controlling those odors eminating from the "throne... I found a product via an advertisement. The name is POOPOURRI. That name summarizes it's function.
It works by a spritz of spray on top of the water. A film developments onto the water surface. This film hides any odor-causing
matter (poo) by keeping the odor UNDER the poopourri film.
Ty it and let us know if it works as advertised.
POOPOURRI.com
I'm a RV.NET member, NOT an employee of poopourri, Thought it a helpful idea for folks
  • If you have potty odors, than maybe your back tank needs a good flushing. I never use chemicals and never have odors. It has taken me years to figure the secret out. The secret is water and lots of it in the tank at all times and good flushing when draining. Steve
  • Bobbo's avatar
    Bobbo
    Explorer III
    I agree. The water in the toilet is the odor barrier, not the poo stuff you spray on it.
  • If water is staying in toilet bowl then it is providing a vapor barrier......no odors can pass thru.
    Might as well spritz some cheap cologne in the toilet.....Brut or High Karate comes to mind
    Just another way for RV'rs to waste their money on aftermarket products that are not needed.
    If you have odors INSIDE your rig..find the source of stink and fix it. Not mask it with snake oil
Looking for advice before your next adventure? Look no further.25,171 PostsLatest Activity: Oct 21, 2025
