time2roll
May 31, 2015Nomad
You might actually do OK with the 35 amp WFCO. It is really the 55+ amp that is problematic. Keep the battery connection short and use #4 wire. Hopefully you have two or more batteries as that will help the boost function. You do not really need boost mode unless you are wanting a fast charge to minimize generator time. Honda 1000 should drive the 35a WFCO just fine.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
