ivbinconned's avatar
ivbinconned
Explorer II
Sep 21, 2022
Power voltage to brakes??
Never been happy with braking on our C Creek. Just installing all new brake assemblies and checked voltage at right rear and it shows only 9.5 volts!!
This is not via the truck. I have it connected directly to a tested 12.6 volt battery .
Should I see that kind of a drop from the battery?
  • You have a bad connection somewhere. Does the other magnets show close to battery voltage? If so the area of problem is pretty limited.
