DrewE
Apr 21, 2016Explorer III
Was the fridge light not working when the fridge wasn't working, or only the compressor not running? If you had light, evidently it was getting power.
Depending on the design of the fridge, it may be possible that the compressor wouldn't start up immediately if it happened to be stopped in the middle of a defrost cycle. Sometimes this is controlled with a little electromechanical timer mechanism, or at least it used to be done that way often.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
