thirtydaZe
Apr 21, 2016Nomad
DrewE wrote:
Was the fridge light not working when the fridge wasn't working, or only the compressor not running? If you had light, evidently it was getting power.
Depending on the design of the fridge, it may be possible that the compressor wouldn't start up immediately if it happened to be stopped in the middle of a defrost cycle. Sometimes this is controlled with a little electromechanical timer mechanism, or at least it used to be done that way often.
It was a situation where the fridge light wasn't on, which is why it drew concern. had the light been on i wouldn't have thought twice about it.
Actually our fridge shows the set temp for the freezer and the fridge in a separate area, which weren't on either. just no power.
So last i looked, last night late all was good and cold as normal.
hopefully it's still going strong.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
