Jhram's avatar
Jhram
Praise for ProPride 3P
Wanted to offer my experience with the Pro-Pride 3P.
My truck: 2016 F-150 with a 3.5 L Eco Boost, 3.55 rear end, max towing package and a 145 inch wheel base. It has a curb weight of 4890 lb, towing capacity of 11,600 lb and a GCWR of 16,900. Truck is stock other than Air Lift ride control air bags.
My trailer: 2017 Jayco 338 RETS. Dry weight 9130 lb. GVWR 11250. 40 ft from tongue to bumper. 12 ft high.
When I bought the trailer I knew I would be pushing my truck to the maximum capabilities. I wasn't concerned about the weigh as one search of You Tube will show videos of similar trucks pulling 14k loads up steep grades without difficulty. My concern of trailer sway. With the trailer outweighing the truck better than 2:1 when fully loaded, the large surface area inherent in a TT and my short wheel base I knew sway could be a huge issue.
After a lot of research and reading the endless debates on forums I decided the 3P was right for me. I placed my order and had boxes on my door step in just a few days.
From this point it was a comedy of errors on my part. Being mechanically inclined I casually read the directions and got to work. Install was a breeze with simple hand tools (though I did have to borrow a torque wrench).
(Below assumes you have a working knowledge of the hitch components)
Because I am pushing my truck to capacity I had to apply a lot of force to the weight distribution bars to distribute weight properly. Because I had installed my stinger level with the ground the force of the WB bars caused the pivoting portion of the hitch (hitch head from here on out) to be nose down. I did not notice this detail before my first test drive.
Thinking I was good to go I took the truck and trailer for a drive. The sway was HORRIBLE. Because the hitch head was not level with the ground it wanted to ride at either extreme of its range of motion. When driving the force of the truck's forward motion kept the hitch head in the proper place but if a gust of wind hit the hitch head would move to one side then when pulled back to the center would over compensate to the opposite side because it wasn't level. This had a pendulum like effect and made the truck nearly undriveable. Additionally when turning at low speeds I heard a loud clunking coming from the hitch. (More on this later.)
I got home from the first drive think the 3P was utter **** and my wife was going to kill me when I told her we needed to buy a diesel pick up. However I remembered from all the forum reading I had done all the praise heaped on Shawn at ProPride for his customer service. I call, left a message and had a call back in 20 minutes. He immediately knew what the issue was and said I needed to lower the angle of my stinger so that once I applied force with the WD bars the hitch head would be level.
I did as instructed and ran into my second problem. When coupling the truck to the trailer the hitch head must be at the same angle as the stinger. To accomplish this you raise or lower the WD bars to achieve the proper hitch head angle. In my case this was not possible. My trailer has a 6 inch frame and the ball coupler is mounted to the bottom of the frame so even using the top hole of the linkage bars and lowering the jacks all the way down I was unable to get the proper angle to hook up. I disconnected the WD bars from the linkage bars and was able to get the proper angle for coupling by manually manipulating them. I took another test drive with the hitch head riding level and all trailer sway was completely eliminated. However I still had the clunking noise coming from the hitch when making low speed turns.
After getting home from test drive two I turned my attention to the clunking. This was when I noticed I had installed the yoke upside down. (Yes, I'm an idiot) The hitch head would knock against the upside down yoke when making turns. The damage to the yoke was significant. Fortunately the hitch head suffered only cosmetic damage. By this point it was late in the day so rather than call I emailed Shawn. I told him about my problems coupling the truck and trailer as well as my yoke damage. Shawn replied early the next day. He said he would make longer linkage bars to help me get the proper angle while coupling and would send out new yoke arms. He charged me only his cost for these pieces and I was thrilled.
Again the parts arrived in a few days. I installed them and was able to hook up the truck and trailer without difficulty. There was one final piece of drama when my WD jack broke. It would turn freely without raising or lowering. A final call to Shawn (which he answered immediately) and he told me I sheared a pin in the jack. Turns out using an impact gun to raise the jack is a bad idea. One trip to Lowe's and 59¢ later the problem was fixed.
I then took a 4 hour trip to Louisiana which was my first time to use the hitch with it working as intended. As others have said the hitch does eliminate sway but it doesn't put you on rales. I was still moved around a bit by wind gusts and passing 18 wheelers but at no point did I ever feel out of control of my vehicle. I was driving on a very windy day and the best description I have is it was like minor airplane turbulence. Wind gusts would move the truck and trailer in tandem and at first it was a bit nerve wracking because I kept waiting for tail-wag-the-dog sway. But it never came. After 15-20 ministers of driving I became used to the new feeling of my vehicle towing with the 3P and it was a pleasure.
Conclusion:
Most of the forums I read agreed the 3P is a superior hitch to the Reese Dual Cam and Equal-i-zer. After all the 3P eliminates sway whereas the others only dampen it. The debate revolves around whether the 3P is enough better to justify the cost. Whether the 3P is worth the cost will vary depending on your tow vehicle and trailer though if you have the funds I would recommended it under any circumstances.
What I can say with confidence is in my case I couldn't have towed my trailer without a 3P. As manufacturers keep increasing the towing rating of half ton trucks situations like mine will became more and more common. To anyone trying to maximize the ability of their half ton to tow a travel trailer a 3P is a must.
Finally, not enough can be said for Shawn, his patience, responsiveness and customer service.
  • downtheroad wrote:
    SouthpawHD wrote:
    Initially I think he might be overloaded on payload as well. However, OP has stated a max tow package.
    That being said, that's still a LOT of trailer for that sized truck.
    Good point, but isn't the "max tow package" different than the "max payload package" on the F150?....or are the one and the same?
    Also thinking of the weight of the ProPride itself....isn't it a really heavy hitch? - counts against the truck's payload also.
    Max tow does little or nothing for payload. You can special order from the factory with a max payload package (which is different from max tow), but even that would be strained with what the OP is planning. No matter what WDH is used, the tongue weight doesn't change. From what I've read, the max tow package still only includes a receiver with a 1000 lb tongue weight limit.
    Oh oh. Another problem for the OP.
    F-150 Max trailer option is NOT the same as Max Payload option. Witout max payload option, he will be well under 1900lbs and more likely 1500-1600lb range. Not good.
  • I am towing 32' with a 122" wheelbase SUV that brings me near the SUV's capacity.
    On paper I am over rear axle weight and 100lbs over gross vehicle weight (basically 100 over payload)
    When connected with the WDH applied I am no where near rear axle weight and I am under gross vehicle weight as well.
    Point being, do not be so quick to judge and claim the OP is over spec. On the scale, with a WDH, things can change and no "legal" weight police have nothing to balk at...on paper.
    NOW...all that said...there is another problem.
    The Propride, like the Hensley have tongue weight maxumums of 1400lbs. There is no way this 40ft trailer is under that.
    The Hensley and Propride have multiple failure points but going over max tongue weight is just asking for the unit to self destruct at the worst moment.
    OP...I am not on the weight police band wagon and rarely do I jump on the "need a bigger truck" bandwagon often found on this site. THIS SITUATION IS AN EXCEPTION. You very likely need a bigger truck.
    I'd get that tongue on a certified scale ASAP.
  • I am in total agreement with you in that the Propride 3P is a fantastic hitch. I too found Sean to be very responsive and helpful. The only problem I have with the 3P at the moment is that we have nothing to attach it to. We sold our trailer last year and are thinking about moving up to a 5th wheel, so our hitch is gathering dust until we buy a new RV. As great as this hitch is I wouldn't be too quick to discount the advice of the "weight police." Most of them know what they are talking about.
  • Initially I think he might be overloaded on payload as well. However, OP has stated a max tow package. If the Ford's max tow package is like GM's, his payload could be around 1800 pounds or so. I had a GM Sierra 1500 max tow and had slightly more than 1800 pounds of payload.
  • I think you've made the PP meet it's match. TOO much TT for that truck. 40' is way long. I just don't get why some people have to get the biggest baddest trailer and then compromise on the truck. IMO I would've thought the PP or HA would've helped more. I know I towed 7300lbs @31' with an F150 with only a 145" WB using an HA and it was great. Really about as good as my 2500 and current 5th wheel.
    But no way would I want to of towed 10,000lbs and 40'. Thats really 2500-3500 territory. The dry tongue weight is 1235lbs dry. Add 90lbs for two batteries, 50lbs for propane and another 100lb+ for stuff in the front and you're close to 1500lbs on the tongue.
    I normally don't go all weight police but in this case I will. You are way way over your receiver rating. More than likely over the RAWR too. You're simply asking TOO much of your truck to be safe.
  • Welcome to the Forum and your 1st post.
    Glad it's working out for you...No doubt, the ProPride is a first rate hitch.
    Your TT is just about the biggest TT available out there....over 11,000 lbs and 40 feet long...That's a load for an F150 (but, what do I know).
    Your concern should be payload. You are unlikely to be within the F-150 max payload capacity when loaded for the road with a TT that large. Just because you can pull it and eliminate sway means nothing when you are looking at a tongue weight of over 1000 pounds (probably well over). Even if your hitch receiver is rated for that much weight (most ½ tons are not), it leaves you with little room for passengers or cargo in the bed. I read threads all the time about people with much smaller trailers than yours who are pushing the limits of their payload capacity. I think you may be pushing your luck on this one.
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: Apr 30, 2025
