RobWNY's avatar
RobWNY
Preferrred Water Heater
Which brand water heater do you prefer? I've had both the steel Suburban and the aluminum Atwood/Dometic. They are both excellent water heaters. Personally, I prefer the Atwood/Dometic but which do you prefer?
  • Lynnmor wrote:
    Depends on your preference; anode rods or soft plastic drain plugs.
    I'll take the soft plastic drain plug any day !
    We don't need to ever change a anode on our residential water heaters, so why should we have to in a RV
    Guy
  • RobWNY wrote:
    Old-Biscuit wrote:
    Atwood
    CONs
    Only one set of t-stats for both AC/Gas operation, DC Relay and AC Element on backside of WH Tank
    That's the only thing I don't like about the Atwood/Dometic HW Tank. Having things on the backside that might need to be replaced. That can be a difficult task by some RV Owners.
    Especially when the 'RV Engineer/Designer' designates WH Location that requires REMOVAL to get to element etc
    STUPID!
  • Old-Biscuit wrote:
    Atwood
    CONs
  • Both have pros/cons
    Suburban
    PROs
    Major components are accessible via outside compartment (Both sets of T-stats, gas valve, electric element, anode rod)
    CONs
    AC & DC Junction Boxes on backside along with circuit board which does not have a Fuse and combustion/exhaust 'U' Tube is stacked so unequal surface contact for heat transfer, Steel glass-lined tank which can not be replaced, NO air shuttle to adjust air/fuel ratio
    Atwood
    PROs
    Aluminum Tank/no anode rod, gas valve accessible, thermal fuse protection, air shutter, diagonal combustion/exhaust 'U' Tube for better heat transfer, Fuse protected circuit board, NYLON Hi Temp/Press drain plug, replacement tanks available
    CONs
    Both Brands are functional, do what they were designed to do and are roughly equal in easy of use
    For me it's a toss up
    Whichever one comes in the RV I purchase is fine!
  • Depends on your preference; anode rods or soft plastic drain plugs.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
