smhnevada's avatar
smhnevada
Pressure Pro sensor problem, maybe
I have a 2004 Winnebago Sunrise, 32 foot Class A. I seem to have bad tire karma. Always had trouble with tire pressure on the rig. Last week had new tires put on, pressured up and re-installed the Pressure Pro sensors. The next day one of the tires had dropped from 85 psi to 69 psi. Same problem I have had many, many times before on different tires with the same Pressure Pro sensors. Swapped out the extender. Next day same problem. The only thing that is now common to all the tire pressure problems is the Pressure Pro sensor. Different tires, new extenders, valve stem checked for leaks. I have read all the great reviews on Pressure Pro systems on this site but am wondering has anyone had a problem with pressure pro sensors leaking air.
Thanks in advance.
  • Pressure Pro has a little rubber seal that sometimes gets "pinched" or torn...this will cause a slow leak. Contact Pressure Pro about having the seals/grommets replaced...
  • I have the Pressure Pro system installed on my F350 and Cedar Creek 2013 36 CKTS fifth wheel. I have noticed that on some of the tire valve stems with the pressure sensor installed have a very slow pressure leak. On these tire valve stems I use Teflon tape which is used for sealing pipe threads. This works well for the few tires that have the slow leak. I assume the slow leak is due to the tire valve stem thread tolerances.
  • Al, thanks for the quick response. I will try moving the sensor try the other tips. Great ideas. The pressure is accurate as I check everything with a standard gauge. It's just so frustrating to continuously having this slow air leak in one of the tires and no one seems to be able to fix it. Have tried Big-O, Camping World, Ted Wiens in Vegas, nothing. Thanks again.
  • Questions - have you tried moving the sensor to another tire to see if the problem moves? Can you verify that the reported sensor pressure is accurate with a standard pressure gauge?
    Sometimes a little dab of lubricant on the valve stem - something like vasaline or dielectric grease - will help the sensor seat better. Sometimes blowing out the valve side of the sensor with compressed air will help.
    Failing that, contact Advantage Pressure Pro and give them your story. I've found them very responsive the few times I've had contact with them.
    Been using a Pressure Pro system since 2007, and never had that problem. And no - I don't sell them, just use them.
    al
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 28, 2025
