Raymon
Mar 20, 2015Explorer
Dave H M wrote:
I would have tried just changing the connector a long time ago.
I have not done but one or two but there was always enough slack to pull the thing out enough to disconnect it and install the new one.
The plastic connector was cracked on one of my RV's. I replaced the plastic connector with a brass connector. Remove the screws holding the round flange to the side of the RV. Gently pull out the connector. On the back will be a hose. The hose should be long enough to pull the connector out to gain access to the back of the connector. Remove the hose and install a new connector. Hope this helps.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
