Wishbone51's avatar
Wishbone51
Pressure regulator on black tank sprayer?
I have year 2000 model Komfort TT with a built-in black tank sprayer. Works great, but water sprays out behind the white swivel hose connector causing a huge mess when I rinse the tanks, unless I hold the hose "just so".
I took the trailer in to have the connector replaced, but they said that they couldn't replicate my issue. After some discussion over the phone, it turns out that they were using an inline pressure regulator while rinsing, and said that I should always use a regulator on the sprayer.
I thought that this shouldn't be necessary, as the sprayer shouldn't be building up enough pressure to require it. Has anyone seen this before? I would think I would want max pressure to spray the tanks.
  • I have never used a regulator on my black tank rinse EXCEPT at two RV parks that had very high water pressure. Used a regulator for the fresh water input also at those.
  • Bobbo's avatar
    Bobbo
    Explorer III
    You either don't have the hose screwed tight enough to seal the hose against the washer, or you have a worn out washer.
    That is a classic symptom of a loose hose connection.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
