WoodturnerII's avatar
WoodturnerII
Problem with Cat scale weights
I recently purchased a 2015 Bay Hill 295RLS. The dry weight in the brochure is 10,646 lbs and the pin weight 2019. I am towing this with a 2010 F-350 pickup with a diesel engine. We loaded everything we are going to travel with in the trailer and went to the Cat scales. Here are the numbers.
Steering axle - 5020
Drive Axle - 8780
Trailer Axle - 7760
Gross - 21560
Unhooked the trailer and weighed the truck.
Steering axle - 5040
Drive Axle - 3640
When I enter these numbers into the worksheet I get 5140 lbs as pin weight which is 40 percent of the total weight of the trailer. There is nothing in the forward compartment except the battery and propane. The tanks are empty except for the water tank which is located behind the rear axles. How can a 12,900 lb trailer have this much pin weight and how do I fix it?
Thanks for any suggestions.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
