RoamingGnomes's avatar
Dec 19, 2014
Propane - when is a fill a true fill
Over the years (12) I have had my propane tanks filled using two methods to determine when the tank is full, by weight using a scale and the second filling until propane escapes from a bleeder valve. When I picked up the tanks after filling I noticed that when they were filled using the bleeder valve method the tanks were heavier & lasted longer. I know which filling method I prefer, but is there a correct method? I have never had any problems using the tanks filled by either method.
Skeptics might doubt about the ability to feel the difference but over time you learn to notice differences visually and physically and although I have never weighted the tanks when filled by the bleeder method the weight feels about 2 pounds heavier. All I know they last longer.
  • It's been my observation that not all propane dispensers are trained equally. Some may use a 'standard' weight for your cylinder instead of actually looking at the tare weight stamped on the collar, then adding for the weight of the nozzle and unsupported hose.
  • LynnandCarol wrote:
    I watched them fill ours last week and they were being weighed at the same time, the bleeder valve started to bleed out @ exactly 7.3 lbs. This is for the 30lb. tank.
    I think you meant 7.3 gallons.
  • I highly doubt they were two pounds heavier but any of three methods is acceptable;
    fill till bleeder releases liquid
    fill till OPD shuts off flow
    fill by weight
    All three methods should fill to the same point.
    I always use a digital fish scale to weigh the LPG DOT cylinders. It is nearly impossible by normal means to weigh a tank that is bolted to a chassis. ;)
  • I watched them fill ours last week and they were being weighed at the same time, the bleeder valve started to bleed out @ exactly 7.3 Gallons. This is for the 30lb. tank.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
