BarabooBob
Jun 24, 2023Explorer III
I learned from experience that you have to turn the propane tanks on slowly so that the system doesn't think that there is a massive leak. This is a quote from etrailer's propane problem solving site:
If your primary valve is fully open and you still don't have propane flowing, the next thing you should check is your excess flow valve. This valve is located in the center of the gas fitting and will limit or stop the flow of propane in your RV if it decides there's an issue. If your excess flow valve is engaged, you're going to have problems.
There are 2 common reasons why your excess flow valve is preventing propane from flowing: a propane leak or your primary valve being opened too quickly.
Check out their site at https://www.etrailer.com/faq-rv-propane-troubleshooting.aspx
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
