I have a 2013 Class C Jayco Redhawk. We have had no issues with it until this summer. When not in use we keep it in a fully enclosed shed. No issues until this summer when from time to time we go...
Propane monitor alarms do go bad. It is not uncommon, and replacements are not very expensive, replacement is plug-and-play. Low voltage, mentioned above, will also give you an alarm fault. However, please consider that you may have a propane leak or a burner valve is open. At very least, turn off the propane at the tank, ventilate the coach, and see if the alarm continues.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
