While most of our trips don't require fueling with the 5er attached. Not sure what I would do? I can simply kill the frige with the 12 volt disco switch. That said the flame is more than 25' from the pump, and US building code only requires that a gas HW heater be 18" above the floor in a garage. Well my frige is about 4' above the ground. so ignition is far less likely.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
