Padlin
Jul 02, 2014Explorer
Propane and Gas Stations
I run my fridge on propane when traveling and have never turned it off when stopping for gas, never thought about it till tonight. Do you turn it off?
jfkmk wrote:So if the guy on the other side of the pump starts his car to leave there should be a big boom.bid_time wrote:
Just one simple question. If the ducks all fell in a row and the situation was right that the fridge could cause an explosion, isn't the same thing likely to happen when I start the car?
Not unless you start the car while actively fueling it.
2012Coleman wrote:dks wrote:Cell phones don't produce static electricity. I saw an episode of Myth Busters where they hun a cell phone inside a plexiglass container which also had gas spraying into it. Several calls to the cell phone produced no explosion. Google it or click here for one version. Static electricity can be an issue if you get back into your car while fueling. If static builds on your clothes - as it usually does, espically in winter, and you touch the nozzel, then yes you could ignite the fumes - as seen in the video. Static electricity can also build up if you put fuel into a portable container that is not on the ground - in the bed of your pickup for instance. They tell you not to use a phone while refueling only to cover themselves.
I turn my propane off, doesn't seem safe to have an open flame around fuel pumps. That's why they have no smoking signs and tell you watch for static electricity with cell phones.
