crazyguamboy's avatar
crazyguamboy
Propane gas detector going off
I have an Atwood propane gas detector in my 15 ft TT. It went off, and I can only guess why. But I'd like some assurance from the knowledgeable. The scenario: door open; screen door closed; burning yard debris about 25 yards away; smoke at times would go toward the direction of the TT, but didn't see it going into it. When the detector sounded, I pressed the test/mute button to mute the alarm. But that was only temporary. I turned off the propane at the tank, and that didn't do anything. The alarm still sounded after the mute time expired. Then I disconnected the battery to reset everything. During this, I turned off and on the fridge and hot water heater to make sure the propane was igniting (and it was). In the evening, when the debris burning subsided, the alarm never went off again. What I want to know is, are these alarms sensitive to smoke as well as propane gas? Like even smoke from a campfire or bbq? Thanks.
  • Their website may have the answer. http://www.askforatwood.com/lp-co-detectors.asp
    If it is a CO alarm it could go off from campfire smoke.
