Has anyone installed a high pressure quick connect alongside the low pressure. If so how? I thought that might be easyer than converting all the appliances we have.
If you want a high pressure line to use your bottle grill with, it is not necessary. Go to your local RV dealer and buy a kit to convert your grill to use the low pressure line on you RV. The kit consist of a long gas line to keep the grill away from the RV when using it and a low pressure regulator to replace the high pressure regulator for the bottle.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 25, 2026
