valhalla360
Apr 27, 2020Navigator
If electricity is included in the cost of the site...of course use electric (assuming you have enough amps).
If you are trying to run the air/con or the electric is charged per KWH and is excessively high priced, then consider propane.
Another thought...if you need hot water quick or you are using a lot of hot water, you typically can run both at the same time and it will heat much quicker.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
