I have a propane problem. I am parked in a permanent location so using the propane tank in my motorhome is not an option. I decided to hook up a 20# tank I could easily refill. I put a two stage re...
The hose connector on 20 and 30# tanks has to depress a valve in the top of the tank inside the valve, where the hose screws in, could that be your problem? With no hose connected you can open the valve on top of the tank and no propane will escape the tank.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
