mikemc53's avatar
mikemc53
Explorer II
Dec 18, 2015
propane question(s)
I have the standard two bottle set-up (30 lb each?) and was wondering a couple of things. This will also solidify my status as a rookie since what I am asking is probably pretty obvious to most.
First of all, if there is no gauge on the tanks, how does one know when they are near empty and need refill?
Is it OK to take off one tank (preferably an empty one) and take it to get filled while teh other is supplying the RV?
Is it difficult to add gauges if there are none cuurently on the tanks?
I will be parked for some time and just want to make sure that when I need to refill that I do it in the proper and most efficient manner.
Thanks gang.
  • When I have two full tanks I always take propane off the starboard tank and keep the other tank valve closed. When the first tank is empty I open the 2nd tank valve and take the first one to be filled.
    For an unknown reason when any tank is getting low we smell propane in and around the RV. That's a clue to open the 2nd tank valve particularly in cold weather so as not to run out.
    I never worry about how much is in either tank with this method.
  • I use off one tank at a time, just because.
    I pour hot water over tanks to check gas level.
  • You should have an auto switchover regulator between the two tanks. The red lever on the regulator points to one of the tanks. You open the valve on that tank first then open the valve on the other tank. The window in the center of the regulator shows green. The regulator now draws propane from the tank the red lever is pointing to. When that tank is empty the regulator automatically switches over to the other tank. When that happens, the window in the regulator shows red. You switch the little red lever over to the other tank, the window in the regulator not shows green again. You take the empty tank off and go get it filled. Hook it back up and you're good to go. Same process as above but now your drawing off the other tank with the recently filled tank standing by and ready to go for the next auto switchover.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
