parkmanaa wrote:
Federal law: Any cylinder less than 100 lb. capacity must be recertified 12
years from date of manufacture stamped on top collar.
This certification must be performed by a propane company licensed to inspect cylinders. I have heard of charges varying from $0, if you have them refill cylinder at the same time, up to as high as $30. This charge is not regulated by law.
Beginning a couple of years ago, re-certification date is applied to a sticker which is affixed to the top collar. It will read month, date, and letter 'E'.
Cylinder must scrapped 5 years from the date beside the letter 'E'.
Close but no cigar....
Cylinders can be recert repeatedly........as long as not damaged and has correct OPD
Propane cylinders less than 100# recert every 12 yrs. from date of mfg. stamped on collar
3 methods of recert
1) 'External Visual'. Good for 5 yrs. Designated by a RIN or VIN valid umber followed by 'E' (Most common recert)
2) 'Proof-Pressure'. Good for 7 yrs. Designated by a RIN valid number followed by an 'S'
3) 'Volumetric-Expansion'. Good for 12 yrs. Designated by a RIN valid number
Information Link
