- DrewEExplorer IIFor astrophotography needs, I would think that a battery/inverter/solar setup would be about ideal. You're likely to be camping in a place with clear, wide-open skies, and the energy usage of the telescope gear and laptops is comparatively modest.
- WackAwayExplorerI purchased the Champion "Dual Fuel" 3500 watt inverter/generator when I bought my 5'r last November. Having a choice of fuels takes away that "not able to find LPG issue.
My 5'r has 2 30lb tanks and I bought 2 spare 30 lb'rs to use for backup, genny, camp stove and fire pit. So far I've only run the genny on LPG and have camped up to 5 days/nights on 1 of the 30 lb tanks while tee'd to the outdoor camp stove.
My truck is diesel so having emergency for the TV is a NA for me.
Also in my case, LPG is cheap since I get a $0.90 per/gal discount from my home LPG provider.
So for me, LPG is my first choice, but I still have the option to buy gasoline if it was the only thing available. - Might do just fine with more battery and inverter. Maybe a small 1000 or 2000 watt portable just in case. Portable may also help if you want to set up 100 yards away on a hill or something. Solar would work in the right conditions and charge your battery the next day.
- Bionic_ManExplorerWhat type of generator? Built in, or portable?
If built in, what type of RV? Class A/B/C, or towable?
How will you use the generator?
What I would suggest for a generator fuel source greatly depends on the answers to the above questions.
To cut to the chase, the only area I might prefer propane is in a towable. Portable generator I would definitely want gas. A RV with a motor, I would prefer the fuel source that the motor runs on.
Even with a towable, I am not sure that the propane is the way to go (and I have a built in propane powered Honda in my 5th wheel. For little stuff like charging batteries, using the microwave, hair dryer, toaster, etc. propane is fine. But when I go and boondock and need to run the air conditioning, it just uses too much fuel. I think it would be much easier to fill with a 5 gallon gas can than to switch out the propane bottles. - DarkSkySeekerExplorerReally good content here, thanks.
- WackAwayExplorerOne more thing to think of...
How sensitive is the equipment you'll be running off of whatever power unit you'll be using? Make sure that you get a pure sinewave type power source. A lot of digital equipment is sensitive to how clean the AC voltage is. Laptops are tolerant, TV's and most positioning servo's are not. I assume your astro-toys have tracking servo's in them, right?
Hope this helps :-) - theoldwizard1Explorer IIIf you boondock a lot you had better have a spare LP tank !
- SCVJeffExploreriMO- Propane should only be used where gas doesn't make sense. For long term storage you can't beat LP. It lasts forever and there's nothing to gum up or go stale. Perfect for a standby residential gen set. There are also laws about commercial gas storage that got us in a pickle at the office. We store an emergency generator at a microwave shack located on top of a large commercial building. The landlord would not allow a flammable liquid up there, but had no issues with a 20lb tank that we store on the roof. Lasts forever, and if it leaks it just vents to the atmosphere. The generator is always ready to go with no fears of contamination.
- tinner12002ExplorerI think if they would start using FI gen sets in RVs they would be much easier to start and way more efficient. You'd still have to keep fuel treated but that's no big deal. I guess a person could get an LP to gas conversion for their gen, then you could switch back and forth as needed.
- WackAwayExplorerHere is the Genny that I bought. Like I said, it gives you the choice of fuels.
Champion 3500 Watt Dual Fuel RV Ready Portable Inverter Generator with Electric Start
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
