- Gr8lifeExplorer IISomeone else can do the math, but seldom does the front axle lose weight after WD is applied.
- mojorooExplorerOk I reweighed just the truck today do to the fact I was in a full on storm and not have had the truck positioned correct. This is without the hitch or WD bars installed. I also was missing about 3-4 gallons of gas and a box that weighs #20.
So is my tongue 1300# or 1080#. Just worried I might be maxing my hitch out which is 1500# when used with WD.
EDIT: Forgot truck alone weight from today. :S
Truck alone today.
Front Axle: 3620#
Rear Axle: 2820#
Total:6440 - mojorooExplorerOk I got some numbers. I had to work fast as storms were reported close in the area after I got the rig on the scale. Winds were blowing at 40-50 MPH so not sure if that made the numbers off.
#1 Hitched without WD. Front 3500# Rear 4240# TT 7360# Total 15100
#2 Hitched WITH WD Front 3400# Rear 4120# TT 7400# Total 14920
#3 Un-hitched from truck Front 3520# Rear 3980# TT 7180# Total 14680
Now on the third one I am 85% sure the scale weighed without me on it. I weight 280# and a storm was in full effect. I also was missing daughters clothing and food in the fridge. - ependydadExplorer
Ron Gratz wrote:
The sequence of the three weighings is a matter of personal choice.
But, if you are going to hitch up the WD bars or unhitch the WD bars while on the scale,
you should ask the operator for permission to do so.
Ron
Good point. I just assumed someone would do that off the scale. Never thought to mention it. - TomG2ExplorerObviously, if there are commercial vehicles in line to use the scales, don't block them while you are hitching/unhitching or messing with your WD hitch. Some scales will want a vehicle number. It can be as simple as your initials followed by a single digit. I prefer dropping off a dozen donuts at my local grain elevator during their off season to using truck stop scales. Most are very friendly.
- ependydadExplorerI also wrote up a blog post on this:
How to Weigh a Travel Trailer - ependydadExplorer
mojoroo wrote:
Thank you all for the replies. So if I am reading this correct.
1)Weigh truck and trailer un-hitched.
2)Weigh truck and trailer hitched with no WD.
3)Weigh truck and trailer hitched with WD
Correction:
1) Weigh truck only
Personally, I would do it in 3, 2, 1 order. But, however you get there is good.
You do not need to weigh the trailer itself. You can get that by doing some math based on the other weightings. - mojorooExplorerThank you all for the replies. So if I am reading this correct.
3)Weigh truck and trailer hitched with WD - Ron_GratzExplorerThe sequence of the three weighings is a matter of personal choice.
Ron - ependydadExplorerFor a travel trailer- assuming that you're doing it at a CAT scale that has 3 scales that you pull onto:
1) Weighing #1 - hooked up and ready for travel - truck's front tires (aka steer axle) on the first pad; truck's rear tires (aka drive axle) on the second pad; all trailer axles on third pad
2) Weighing #2 - disconnect the WDH bars and put them into the truck bed - same axles/arrangement as #1
3) Weighing #3 - park the camper in a truck spot and move the WDH bars to the camper - same truck axles as weighing #1
Throughout all 3 weighs, nothing should change - no moving of passengers, no one goes to the bathroom, etc. Do them all at once (not before and after a trip, for instance).
If you're weighing at a different scale - you essentially want all of the same weights, you'll just have to move the truck more often to get individual weights.
If you're going to a CAT scale, it can be a challenge to reach the call button. I found I had to stretch, but I could reach it (just not hear real well). Many people are taking a short 3' stick of some sort to push it *or* going inside ahead of time to get the phone number of the weigh desk and calling that instead of using the button.
My CAT scale weightings costed me $10 for the first weigh and then $1 or $2 for each re-weigh.
Finally, load the truck and camper as if you were going camping. Family in the truck, carp in the truck bed, etc.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
