Lantley
Jul 10, 2021Nomad
wra wrote:
I notice that some answers mention having no hot water and suddenly having too hot water, having to mix cold water, or needing high flow to turn unit on. All these problem are due to not having the the correct hot water unit or not having it set properly. The correct gpm flow should come on less than half a gallon per minute. The temperature should be set to the temperature desired with no mixing of cold water. That way, the water takes less time to get to the point of use, and does not waste electricity or propane heating water to temperature not needed. That is the purposes of tankless heaters; that you do NOT heat water higher than you need, as well as not keeping water hot when you are not using it. This applies to RV and stick home use.
Tankless for RV's maybe a good idea on paper but in reality there are lots of obstacles. Firts issue is the incoming water pressure varies with the campground. The end user does nothave full control over the incoming water pressure
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
