roadrat57's avatar
roadrat57
Protecting Toad
Is it necessary to add a debris/rock flap to the lower rear for the purpose of protecting a towed vehicle? Is see some class A with this add-on.
Thanks!
  • IMHO there are two better solutions. Mud flaps as close to the rear wheels as possible. Second, Protect-A-Tow under the tow bar. A total rear flap can cause a vacuum and actually cause stuff to fly up onto the toad. We had a full rear flap. I took it off and made mud flaps out of it and used the mounting bar to make a frame to hold the mud flaps with.
    As double protection we also use the above mentioned Protect-A-Tow. It is very easy to attach and works a treat.
  • if they are too low they will kick up stones when the drag.
    bumpy
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
