MvanderExplorerMay 16, 2013PSI questionHi Everyone. Looking for an answer/opinion on the following. I swapped out my trailer tires this week and up-gradded to a load range C from a B that were the original tires. I havent pulled the TT aro...Show More
K_CharlesExplorerMay 16, 2013If the tires have 1760 lb on them you should run 50 PSI, if less weight then you could run less PSI.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
Related ContentPSItire psiDually air psi questionNew tire psi question...Tire PSI and truck camper question
