BarneyS wrote:
There is absolutely no need to combine the two hitches! In fact, I don't think it is even possible. Where would you put the Equal-i-zer? The Pullritte is probably the best hitch that money can buy. It provides the weight distribution that you want plus the best sway control/prevention in the business.
It does use chains and spring bars like a normal hitch does to distribute the weight.
The Equal-i-zer will most likely do the job for you but is not in the same league as the Pullrite.
In my opinion, there is no question about which hitch I would install - the Pullrite.
Barney
Right on the money...
If you do decide to go with the Equalizier - you can send me the Pullrite ....:)
