- HammerboyExplorerI had a Superglide for my last fifth wheel we bought in '04. Well built hitch but on our new rig I installed a B&W Patriot. Our Superglide capture plate I ended up tack welding it on as I had issues with the screws shearing off. I also didn't care for having to be relatively straight on to hitch and unhitch, and the extra maintenance involved.
Dan mighty7sd wrote:
I just got a superglide and my storage lot uses a forklift as well so it's not a problem.
I'd be concerned that the nylon spacer block would deteriorate from constant removal of the capture plate.
I understand that you have to be straight on to hitch up, but as I haven't tried, do you also have to be straight on when you unhitch?
Yes , I believe it something like 8 degree of/on... In the 9 years I have had my capture plate, hooking and unhooking straight has never been an issue,, YET - - - -- mighty7sdExplorerI just got a superglide and my storage lot uses a forklift as well so it's not a problem.
I understand that you have to be straight on to hitch up, but as I haven't tried, do you also have to be straight on when you unhitch? - Have had my 18k superglide since "07" and its worth every penny..
As far as service, i leave it on and mention it to the service writer... its never been a problem with their forklifts and cups.... spud1957 wrote:
Thanks guys. How do you like the hitch?
Having to be almost in a straight line with the trailer hooking/unhooking an issue?
Most times it is not a problem. One time I just couldn't get straight I just pulled the two pins holding the hitch head on and lifted the hitch head out of the cradle using the landing gear. Once the truck was out of the way I pulled the pin and slid the head off the pin to place it back on the hitch. Funny thing is the site I had to do that at, I have been back into many times and got straight every time to unhook.- Colo_NativeExplorer
That is my biggest issue is you can only be off by a little to hitch up and I have had some issues in the storage lot because it is on a slope and it doesn't want to release the pin. Also I always keep a lock on the hitch so the plate can't be taken. - C_B_Explorer II
IMHO there is no better slider!
I've had mine since 2003 and haven't had a hitch/unhitch issue yet.
C.B. time2roll wrote:
Most dealers afaik use a fork lift with a cup to move trailers around.
They don't have the time to hitch up or the space to maneuver a truck around.
Besides it will not be the first SG hitch they have seen.
The problem is they are not looking at the superglide hitch. They are looking at a capture plate that, unless you are looking for it, is really hard to notice. The part that makes it different is a wedge extending out directly behind the pin. It hides rather well.
Taking the plate off takes 2 minutes and removes all chance of it being missed.
Not taking the plate off leaves the chance that the capture plate, pin box and possibly the hitch on whatever the dealer uses will be damaged.- spud1957Explorer
Not the dealer I just my my 5th wheel from. Fork lift yes, but they use a 5th wheel plate the same size as a hitch. - Most dealers afaik use a fork lift with a cup to move trailers around.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
