ricks99's avatar
ricks99
Pulls to right when I brake, what to check?
On our way home from our most recent trip, I noticed that when I break, my truck & trailer pulled to the right.
I verified that my TV does not pull when braking by itself. I had brakes replaced less than 2000 miles ago.
The HTT has ~6,000 miles on it.
Is there something easy (visual) that I can check or adjust? If I crawl under the HTT, should I be looking for something specific, before I break (no pun intended) down and take it in for service?
I've checked and cleaned the 7-pin connector already.
TIA
  • DutchmenSport wrote:
    You've eliminated the pull is caused by the trailer. Now verify the pull is caused by the truck. Unhitch the trailer and take the truck for a drive, hit the brakes hard. See if it pulls. If so, then at least you KNOW the problem is the truck, not the trailer. That eliminated 50 percent of the equation right from the start.
    Good luck.
    Sorry if I wasn't clear... the TV does not not pull when braking. I only experience the pull while towing (which led me to believe the issue is with my HTT -- not my TV. Right?
  • You've eliminated the pull is caused by the trailer. Now verify the pull is caused by the truck. Unhitch the trailer and take the truck for a drive, hit the brakes hard. See if it pulls. If so, then at least you KNOW the problem is the truck, not the trailer. That eliminated 50 percent of the equation right from the start.
    Good luck.
