rekoj71
Dec 03, 2015Explorer
X2 Not too much. That's only about 6 or 7 hours a month, and yes if he had passengers in the back while traveling he may have used it for A/C, or could have used it boondocking a few times.
I looked at your floorplan and you should be able to use the RV even if the slide is in, it will just be tight. Most motorhomes are like this. Trailers have a bigger problem with not being able to use some things when the slides are in but motorhomes tend to allow for passenger movement. That's also why you don't see super deep slides on motorhomes but may on some trailers.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
