Bumpyroad
Oct 27, 2020Explorer
down home wrote:
We had a few nights of freezing temps in Az and ice in the fresh water supply hose. Flushed out after a minute or two but... one of the heated hoses with 110 plug is in order. Price of over a hundred to over 200 according to length galls me though. I know I can use from the tank and refill during thee day but that's another chore...when it is cold outside! We had installed a 50 amp box at wife's Sisters for our stay but not a 110...so I'm thinking of getting a tech to run a 120ac plug from the other side of the coach that has two or three in the bays. May need a separate wire an breaker though as intend some sort of small forced air heater with weather tight or resistant housing and thermostat to make sure the tangs are warm and the wet bay. Just need the layout and drawing it up before any cutting etc. Would also come in handy going down the road. The furnaces heat the bays some but...
***came cross this MH Service Bay Heater: 12volt apparently with plug
List several MFGs that use it or that it will fit.
https://shop.findmyrvparts.com/wet-bay-heater-service-bay-3000rv-monaco-rv-parts-p/3000rv.htm
don't fully understand your post, but if you have a 50 amp hookup, you have 120 available
bumpy
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
