CharlesinGA
Oct 06, 2021Explorer
valhalla360 wrote:
As mentioned, if you never plan to use it...who cares.
That said, we use the tank and pump even on full hookup. Had an experience on our boat many years ago, heard a slight hissing sound late at night. Searched it out and found the city water had sprung a pinhole leak. If it hadn't been dead silent, it would have continued for hours or days without us noticing.
Running off the water tank with the pump, if there is a small leak, we will hear the pump kick over periodically alerting us that there is an issue. The RV may not sink but the floors can certainly rot out.
Boats sink when they fill up with water, rv's just get totaled.
Co-worker took his neice/nephew (don't remember the exact details of who they were) with him camping. they used the shower while on city water, shut off the water at the shower head, which leaves it dribbling by design to keep hot water flowing, and to alert you the faucets are on. Well, he failed to follow after them and check that all was properly turned off, and they went to bed only to wake up to an RV standing in water inside. The gray tank had overfilled and the shower pan filled up and overflowed. insurance totaled the trailer.
I do not hook up to city water, I fill the tank and use the pump, and turn the pump off when not using it. I turn the water heater off when not using it, also.
I too listen for the pump cycling when it should not, and that is the clue I should go investigating for a leak or a leaking check valve in the pump.
Charles
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
