Heybro's avatar
Heybro
Question about tires
I have been learning a lot about tongue weight and payload capacity lately, but I have not even looked into tire capacity and weight rating at all. I am going to need some help with this. So my truck has Goodyear 275/55R20 113T tires. It says the treadwear is 500, Traction B, Temperature B. It also says the max load is 2535 lbs, and max psi is 51.
My GAWR on my truck with those tires is 4000 lbs on the front, and 4150 lbs on the rear.
Ok, with that information, how do I figure out if I am good to tow a 7,000 lbs GVWR trailer, with 680 lbs of dry tongue weight without having a tire blowout? I heard something that you need D or E rated tires if you are going to tow. But it looks like my tires can handle 2535 lbs each, so shouldnt i be fine?
  • "My GAWR on my truck with those tires is 4000 lbs on the front, and 4150 lbs on the rear."
    That will not change regadless of tires you put on vehicle.
    Those ARE your Axle Weight Ratings....which you need to stay AT or UNDER
    Your tires are rated at MAX Load/MAX PSI of 2535# EACH------ 5070# Total per axle....MORE then the Axle Ratings
    AS suggested.....when towing 42PSI in Front Tires and 51psi (MAX) in Rear tires
    When NOT Towing...adjust air to 30psi/F and 33psi/R
  • MFL wrote:
    The door sticker is for best ride, but for towing heavy, you need to air up to get full use of tire load capability. Like mentioned full pressure in rear, and try about 42 in the front. A bit of trial, to know what handles best, after all hooked up and towing.
    Jerry
    Thank you for the explanation.
  • The door sticker is for best ride, but for towing heavy, you need to air up to get full use of tire load capability. Like mentioned full pressure in rear, and try about 42 in the front. A bit of trial, to know what handles best, after all hooked up and towing.
    Jerry
  • MFL wrote:
    The tires will work, air the rear to max, no problem there, but you will need to stay under the truck RAWR 4150. If you add the loaded hitch wt to the R/A curb wt. and all other wt added to truck, in cab, in bed, WDH, etc, you still need to stay within rear axle rating. I think it will work, if you don't load the truck bed with heavy stuff.
    Jerry
    Okay, so on the sticker in my door it says that the cold tire pressure should be 30 psi on front, and 33 psi in back. I guess I'm confused on why it says on the actual tire that the max is 51 psi. Should I have them all at 51 psi at all times?
  • The tires will work, air the rear to max, no problem there, but you will need to stay under the truck RAWR 4150. If you add the loaded hitch wt to the R/A curb wt. and all other wt added to truck, in cab, in bed, WDH, etc, you still need to stay within rear axle rating. I think it will work, if you don't load the truck bed with heavy stuff.
    Jerry
  • It doesnt specify on the wheels. I think its P if it doesnt tell you.
  • Forget all “dry” weights. Tongue weight wet and loaded needs to be 12 to 15 percent of trailer weight. 840 to 1050 pounds for a 7000 pound trailer.
  • Are your tires P for passenger car or LT for light truck?
    A P tire may indeed hold the weight without damage but they're designed for ride comfort and thus have sidewalls with less stiffness. An LT tire, while supporting the same weight, will have a stiffer side wall for less rolling and flexing while under way.
    As for knowing if you can tow that trailer, information on your vehicle is necessary, not just the tires. What vehicle are we talking about? What's it's tow rating, hitch rating, payload rating, etc?
    Dry tongue weight is meaningless since no body tows a dry trailer. Your tongue weight needs to be about 13% of the loaded trailer weight so figure about 900 pounds on loaded tongue weight.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Aug 30, 2022
