CampCritter's avatar
CampCritter
Question about trailer brakes
My brake coils on a Dexter 3500 pound axle are not wearing flat. There is a ridge at the bottom of the coil as if that portion of the coil is beyond the armature on the hub and isn't seeing the wear that the rest of the coil gets.
The ridge is quite noticeable and I'd estimate it at about 1/16" high.
The Dexter manual states that the magnets should be replaced if worn unevenly or abnormally.
Manuals are not always correct though. Has anyone seen this type of wear? Is it normal? If not, what can I do to prevent it? Should I replace the coils?
  • Ballpark mileage on those brakes?
    For that wear on the magnets, the drum must have a groove in it. If everything works and the drum groove isn't too deep, I'd just use it as is. Other wise, if you replace the magnet, you need to replace the drum or the new magnet will wear the same as the old one.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Jan 02, 2026
